Need help and opinion on my first gaming build .......
nimabrave999
45
Hello,
i want to build my first gaming pc.My budget for this build is $900[doesn't include OS and monitor but include a device that can connet to internet wired wireless and also play LAN games (i dont know what we call the device is)]. im not very expert in this things .... I'm planning with this :
CPU:AMD Black Edition - AMD FX -6300 3.5 GHz 6-core Processor + OC ($130)
GPU:Radeon R9 270 2GB ($190)
($XXXX) is my budget/estimate price for that hardware....
my question is :
1) is the cpu and gpu is a great combination ? if not what is your suggestion (if can please tell me the reason)...
2) i need suggestion for the case, motherboard and power supply and maybe for the other parts...
3) i also plannig to oc the cpu .... so i need suggestion for the cooler...
SORRY FOR MY BAD ENGLISH
btw i'm not from europe...
thanks in advance
CHEERS 🙂)
Where are you from?Prices vary country to country.Perhaps if you could link to us the store(s) that you'll be using and your budget,we would be able to help better.
I can use a service to ship from us to my country.....
my budget is for the us price....
thanks for the reply
CHEERS 🙂)
as stated above ($900) USD
CHEERS 🙂)
Apologies,didn't see that.This is what i would go with
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.98 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard ($84.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($68.00 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: Asus Radeon R9 280X 3GB Video Card ($319.99 @ B&H)
Case: Corsair 300R ATX Mid Tower Case ($59.99 @ Microcenter)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($59.99 @ NCIX US)
Total: $832.90
(Generated by PCPartPicker 2013-12-23 06:01 EST-0500)
Do keep in mind that this is excluding your shipping costs to your place.
Edit😀o you already have an OS?
i will find the OS later.... the budget doesn't include OS and monitor but include a device that can connet to internet wired wireless and also play LAN games (i dont know what we call the device is) ....
CHEERS 🙂)
Wired and wireless?On the PC itself or?
If it's on the PC,the motherboard already has an ethernet jack.For wireless,you are looking for a wifi adapter.Try looking for a USB WiFi adapter.You should be able to find a fair few.Find one that suits your budget.
The other device is the router.This is where you can plug in your ethernet cable,and create a wireless network for wherever your home/office/room
the device that enable me to join wireless LAN?
CHEERS 🙂
do i need to oc the cpu for gaming?
Ah,so you want your PC to join a wireless network?You're looking for a USB WiFi adapter.
OC is not,strictly speaking,necessary.If you want to,you can.If you think your performance is not good,then you can try OCing
