Hello everyone.
I am in the market for a new monitor and cannot decide on what to get. I currently have a Samsung syncmaster P2250 LCD screen which is quite ancient, but I will still be using it as my secondary monitor for multitasking.
Now the choices I have been looking at is :
1) http://www.bhphotovideo.com/c/product/925856-REG/asus_vs278q_p_27_led_monitor.html
2) http://www.bhphotovideo.com/c/search?Ntt=ASUS+VG248QE&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
Now the thing I cannot decide between is if I am going to like the size of the 27" more or the 144Hz refresh rate of the 24" more. Since this is my budget limit already I cannot afford to go with a 27" 144Hz screen.
I am running a GTX 770 2GB at the moment so I probably will not be reaching 144 fps in new games anyway (I do intend to use this foir gaming btw) , but I also play alot of Dota which wont be so heavy on my GPU.
So would you say refresh rate or size or should I maybe wait before I buy and save up for a better screen? Maybe a 1440p resolution screen? Since I have had this screen forever almost I really don't know allot about monitors.
Any help or opinions would be appreciated.
p.s. About option 3 - Waiting to save up more - If possible only recommend this if you REALLY feel I would be making a mistake since I'm quite itchy to buy the new one now
