Question Need help asap dont know what to do
Sep 29, 2020
9
Okay so about 2 weeks ago my mic dropped on my pc 2 times and caused it to freeze and turn off and on 2nd time it no longer posts but all fans spin, I have tried to use another motherboard still same thing I'm thinking its a power supply problem but I'm not sure
punkncat
Polypheme
Ambassador
Yes I think it might of shorted it aswell
The only thing I can consider could have happened is if you are on a hard drive that was in use at that moment. Obviously, any hard impact to electronics can be harmful.
I could be wrong here, but my understanding of current and the way a PC case is made, that assuming (for instance) that the ground in your electrical wall plug is correct, adding a quick shock to the case itself should not result in damage. I don't know about sustained current.
I would do a quick check of all connections, try to use iGPU if your computer is so equipped, check all the RAM is plugged in, etc.
Sep 29, 2020
9
Reseated everything and tried igpu its so weird and anonnying issue
