need help ASAP
There's no point in getting that Z97 motherboard with the 4460 because the 4460 can't be overclocked. The case is decent from what i skimmed over in the website's description and specs. If you're planning to stick with the 4460 then I would recommend the MSI H97M-G43 Motherboard. Not to sure what you meant about "also will I need to update the bois to work with the motherboard"
