A akos_2 Prominent Apr 26, 2017 4 0 510 May 8, 2017 #1 Hi so i want to buy a new graphics card but i dont know whats the difference between the evga 1050 ti dual fan and gigabyte 1050 ti dual fan. They are about the same price so i am not worried about that i just wanna know which one is better
Solution RobCrezz May 8, 2017 One is made by Evga, one is made by Gigabyte. They both use the exact same GPU. Get whichever you prefer the look of, if the price is the same. Will literally make no difference.
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 May 8, 2017 Solution #2 One is made by Evga, one is made by Gigabyte. They both use the exact same GPU. Get whichever you prefer the look of, if the price is the same. Will literally make no difference. Upvote 0 Downvote Solution
13thmonkey Titan Jan 10, 2006 24,791 350 75,790 May 8, 2017 #3 in what way is this as ASAP problem? Upvote 1 Downvote
