Having problem with my gtx 970 4gb version.. whenever I connect my pcie and try to boot it give me this erro.. please power down And connect the pcie cable to this graphic card..I tried my friend gtx 1060 and it works fine.. please help...
You already tried a known good alternative and it worked so your GPU is probably dead.
i don't understand.. the gpu display something... the message was.. I should power down and connect pcie connect to this graphic card...You already tried a known good alternative and it worked so your GPU is probably dead.
I should connect pcie cable to this graphic cardi don't understand.. the gpu display something... the message was.. I should power down and connect pcie connect to this graphic card...
Did you use the same power cables when you installed your friends 1060? If you did then most likely it isn't the PSU and the GPU is probably dead, however, you could try other 8 pin PCIe cables to make sure. That being said my best guess is the power delivery system on the GPU stopped working.Yes I do and I'm sure it connect properly but it still display the erro message...
