That is acceptable. If the radiator takes up the rear fan position, you could use the SYS_FAN header near the back corner. As long as you run the pump at constant speed, it doesn't matter where it is plugged in.But is running the pump in cpu_opt correct. The fan on the radiator is plugged into cpu fan
Generally running the pump at full speed is recommended.hi I'm using corsair h60 cooler on a gigabyte z170 gaming 7 mb . I have the pump set to cpu_opt. Is this correct. Looking at bios I have set cpu_opt to run at full speed which is at 4200 rpm. Is this safe. Please help
Ok thanks. I will leave it as it is. Just worried that the pump wouldn't work being plugged into cpu_optThat is acceptable. If the radiator takes up the rear fan position, you could use the SYS_FAN header near the back corner. As long as you run the pump at constant speed, it doesn't matter where it is plugged in.
