NEED HELP ASAP
ThatMoose
152
Hello
I am building a computer as I type. On the Mobo I am using the asus rampage iv extreme there is 6 pin power connector to the bottom left of the left ram slots lust above the first pic slot. There is no easy way to plug the a power cord into it, do I need to plug it in?
Thanks very much
To me that looks like a 6-pin PCI-E power port, iv heard of some mobo's using them but never knew which ones.
I would look in the manual, that should say definitively if you do or don't need to connect it. I suspect you dont given its odd placement and that most other mobo's dont require it.
