Need help badly.
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.fic (More info?)
I just received my new mobo today, FIC AU13, set up with a AMD XP3200
processor and 512 mb or DDR3200 Ram. I then placed my video card and sound
cards in the box, figuring I'd just use the onboard lan. I installed a brand
new Western Digital 160 gb hard drive and the first problem was the freaking
floppy wouldn't work!! I wanted to use the Win 98 setup disk to format the
HD. Any ideas there? I noticed the light on, which normally indicates the
cable reversed, but even after I switched it around, the light stayed on.
Reversed on the board? I don't know anymore. Anyway, I booted from the
Western Digital CD and then had no idea what was up, called their tech
support and was told to load Windows XP Pro. I placed that CD into the drive
and it began the installation process. Now even that takes a dump....the
error message is:
STOP: 0x000000CA (0x8236003, 0x82340C08, 0x00000000)
Anyone have any idea what that's all about?
Any help will be appreciated...
Gerry Wolf
gwolf@wi.rr.com
Fatal Error in Plug and Play:
http://www.osronline.com/ddkx/ddtools/bccodes_9h9j.htm
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"Gerry Wolf" <gwolf@wi.rr.com> wrote in message
news:US52d.42170$6h7.40218@twister.rdc-kc.rr.com...
> brand
> freaking
> drive
> error message is:
> Gerry Wolf
> gwolf@wi.rr.com
