Need help! Blue Snowball CMUSBDAC.sys Error
gearshiftstudios
4
Not sure if this is the best place to ask about this, but my Blue Snowball keeps giving me CMUSBDAC.sys error. I have installed the ASIO4ALL drivers and my computer still crashes. It happens randomly, but usually when I am recording (which is a lot so it could possibly be a coincidence). It worked really well for a while but here recently it started to crash more (5 times within a 2 hour period once). I am using a different cable than the stock on because it messed up that means anything.
This also happens to me once a day. Installing the drivers did not help at all. The cause I found was when I slightly touched the wire or made it disconnect, it would BSOD with the same error you got.
