Need help build pc
bcooper56
20
Ok i need help i want to build a gaming pc under 2000$ that will run most of curent games today like bioshock, the withcer and crysis.
Also when i choose parts where is best place to buy them?
Hmm ok in that list of games the only one which will be a 'problem' would be Crysis so once we design to address that game everything else should fall in nicely hehe. Suggested config:
$1298.90
$ 12.18 shipping
$ 50.00 mail in rebates
$1261.08 total expenses
fullmetall
1,698
Go i7, if your going to show the money, get what you need. x4 940 is more of the Budget builder type. He has money to spend on a nice i7 core.
$1500-$1600 at most.
LG 22x DVD
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Vista Home - 64bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
BenQ 24"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014181
Coolermaster RC-690 ( Could go Fulltower if needed )
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Asus P6T Deluxe V2
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365
Sapphire 4870 1gb( could go GTX 285/ATI 4890 if wanted )
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
750tx PSU ( recommended PSU for this usage, if any sli/CF get 850tx + )
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
i7 920
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
OCZ Platinums 3x2gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
WD Black 640gb HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Arctic Silver thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Xigmatek s1283v
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Comes out to be $1650
Can raise the Card to a GTX 285
Price goes to $1805
raise the PSU for later usage
850tx and EVGA 285 changes = $1830 with shipping and without rebates.
If you want full tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
coolermaster HAF
Price is at $1905
