Need help building a budget gaming PC.
Sarum
29
So I would like to build a gaming PC on a budget. The budget would be 1200 Litas what is about 468 in US dollars. All the parts I will be buying is from www.skytech.lt . The parts I need are: CPU, GPU, MOBO, RAM and a PSU.
I will leave the links of each component as there's no English option available.
CPU's: http://www.skytech.lt/procesoriai-stac-komp-procesoriai-desktop-cpu-c-86_85_182_584.html
GPU's: http://www.skytech.lt/vaizdo-plokstes-priedai-vaizdo-plokstes-vga-c-86_85_197_284.html
MOBO's: http://www.skytech.lt/pagrindines-plokstes-priedai-pagrindines-plokstes-c-86_85_826_248.html
RAM: http://www.skytech.lt/operatyvine-atmintis-stac-komp-atmintis-dimm-c-86_85_217_419.html
PSU's: http://www.skytech.lt/kompiuteriu-komponentai-maitinimo-blokai-c-86_85_300.html?sand=0&pav=0&sort=5a&grp=1
I would be grateful if you could help me guys.
AMD or Intel?
FX-6300 but only 4GB of RAM (You can add more later.)
CPU: AMD FX-6300, socket AM3+, 64bit, 3,5GHz, 95W, cache 14MB, BOX // 351.00Lt
http://www.skytech.lt/fd6300wmhkbox-amd-fx6300-socket-am3-64bit-35ghz-95w-cache-14mb-box-p-134676.html
Mobo: Gigabyte GA-970A-DS3P, 970, DualDDR3-1866, SATA3, RAID, ATX // 206.00Lt
http://www.skytech.lt/ga970ads3p-gigabyte-ga970ads3p-970-dualddr31866-sata3-raid-atx-p-150269.html
RAM: DDR3 Corsair Vengeance Black 4GB 1600MHz CL9 1.5V // 136.00Lt
http://www.skytech.lt/cmz4gx3m1a1600c9-ddr3-corsair-vengeance-black-4gb-1600mhz-cl9-15v-p-67533.html
GPU: MSI Radeon R7 260 OC, 1GB GDDR5 (128 Bit), HDMI, 2xDVI, DP // 280.00Lt...
AMD or Intel?
http://www.skytech.lt/260-1gd5-msi-radeon-260-1gb-gddr5-128-bit-hdmi-2xdvi-p-182855.html
PSU: S12II-520 PSU Seasonic S12II-520 520W 80 Plus Bronze retail // 210.00Lt
http://www.skytech.lt/s12ii520-psu-seasonic-s12ii520-520w-plus-bronze-retail-p-71698.html
Total: 1183Lt
Intel i3 with 4GB RAM (You can add another 1 stick of 4GB later.)
CPU: Intel Core i3-4330, Dual Core, 3.50GHz, 4MB, LGA1150, 22nm, 54W, VGA, BOX // 394.00Lt
http://www.skytech.lt/bx80646i34330-intel-core-i34330-dual-core-350ghz-4mb-lga1150-22nm-54w-vga-box-p-161099.html
Mobo: ASRock H81M, H81, DualDDR3-1600, SATA3, HDMI, DVI, D-Sub mATX // 162.00Lt
http://www.skytech.lt/h81m-asrock-h81m-h81-dualddr31600-sata3-hdmi-dvi-dsub-matx-p-160155.html
RAM: DDR3 Kingston HyperX blu 4GB 1600MHz CL9 // 128.00Lt
http://www.skytech.lt/khx1600c9d3b14g-ddr3-kingston-hyperx-blu-4gb-1600mhz-cl9-p-86305.html
Total: 1174Lt
