Need Help! Building a budget Intel Gaming rig for PUBG for $550
kitOy88
41
Good day fellas! I'm just a newbie about PC and I want to build a rig basically for PUBG that can run a decent 60 - 90 fps. I'm thinking of this specs
CPU - G4560 (what can you recommend better?)
GPU - GTX 1050ti (fix)
RAM - 8gb (2x4gb) Dual Channel
Understood. Do you have a budget in Pesos and links to the sites you would order from?
Are you able to pick up a ryzen 3 1200 and b350 or even a320 mobo within that price? Or a Ryzen 5 1600 and br350/a320?
EDIT: Apologies, missed the $550 in the title.
Here:
PCPartPicker part list: https://pcpartpicker.com/list/Kcm3tg
Price breakdown by merchant: https://pcpartpicker.com/list/Kcm3tg/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor ($94.89 @ OutletPC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard ($59.99 @ Newegg Business)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($84.99 @ Newegg)
Storage: Western...
kitOy88
41
well, if I can get a decent 60 fps, then maybe i'll go for GTX 1050 ti + G4560?
Here:
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($43.85 @ OutletPC)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card ($204.98 @ Newegg)
Case: Thermaltake - Versa H21 Window ATX Mid Tower Case ($19.99 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($28.99 @ Newegg)
Total: $537.68
Generated by PCPartPicker 2018-04-12 21:16 EDT-0400
kitOy88
41
Thankyou so much, good sir!
kitOy88
41
I don't want to give you any hopes. Both are seriously going to hold you back getting that high without dropping to 720p or running with low quality settings bigtime at 1080p. You can read a full report of tests here:
CPU - https://www.techspot.com/article/1532-pubg-cpu-benchmarks/
GPU - https://www.techspot.com/article/1551-pubg-graphics-benchmarks/
TL/DR: there is no budget PUBG build that hits 60-90fps at 1080p with medium or above quality.
