as the title says, i'm building my first pc soon with a budget of around 60,000 INR
i need you guys to tell me if i need to change anything before i go ahead
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($163.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.89 @ OutletPC)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard ($88.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1066 Memory ($54.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($67.98 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: MSI GeForce GTX 960 2GB Video Card ($179.99 @ Newegg)
Case: Cooler Master Storm Scout 2 (Black) ATX Mid Tower Case ($111.99 @ Amazon)
Power Supply: SeaSonic X Series 660W 80+ Gold Certified Fully-Modular ATX Power Supply
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter ($34.80 @ Amazon)
Total: $784.06
Generated by PCPartPicker 2015-04-23 05:51 EDT-0400
my main questions are: is the motherboard good? and what will i lose out going micro atx compared to atx
and if the cooler master cm 690 iii (windowed) is better than the cooler master storm scout 2
i really like the handle on the scout but wanted to know which is better for a first time builder and if thee scout was worth it
the power supply might change but its definitely going to be a gold rated power supply so can you suggest power supplies that i should go for/avoid
i am getting these parts from a local dealer if that helps
Total: $784.06
