Need help building a gaming PC
Sure thing.
Grab this, get everything except the GPU, and grab that later, 1060 prices are a little high, and if you're going to exclude anything there it won't work anyway.
Everything but the GPU is good value right now.
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor ($79.89 @ B&H)
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard ($56.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-2133 Memory ($60.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING...
Let me tell you the estimate:
- DELL 790 with Core i5 3.3ghz 2nd generation, 4GB RAM, 250GB HDD - $140
- GTX 1050ti 4GB - $210
- 22" LED Monitor - $70
Total: $420 excluding keyboard and mouse.
Someone told me that this desktop will be heat machine if I do 1080p gaming and rendering on it. After that, I changed my mind and want to build my own PC:
- Corsair Spec Alpha or Thermaltake N26
- Gigabyte B250M D3H motherboard
- 8GB RAM
- 500W Power Supply
- GTX 1050ti 4GB MSI or Gigabyte
- 1TB HDD
- Core i5 2nd generation
I haven't mentioned the prices because online rates are higher than local markets. But still rough estimate is $500.
I have saw on youtube about Pentium g4560. What you say about my parts and if I buy Pentium one? With which processor it is equivalent? Sorry for bad English :) but I know you will understand.
Which parts you recommend me for 1080p gaming and rendering? What I want:
8GB RAM, 1TB HARD, Core i5, Gigabyte B250M D3H, GTX 1050ti 4GB.
If these specs gives me smooth gaming, well and good,or you recommend me under $500 budget. Thank you.
Sure thing.
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card ($224.98 @ Newegg)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case ($17.99 @ Newegg)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply ($34.98 @ Newegg)
Total: $523.69
Generated by PCPartPicker 2017-07-26 08:48 EDT-0400
