Question Need help building a gaming pc
Apr 13, 2019
Hey, I want to build a gaming pc capable of running most games at stable fps 50+ fps, I have 400$ budget what would you guys recommend ?
Am thinking of a i5 3rd gen cpu, and RX580 gpu ,8gb DDR3 ram.
Ill be mainly playing Fortnite and i want a stable 60fps or more
Unless you are awayre of some deal, for that budget ballpark this is the best you can get...
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor ($94.89 @ OutletPC)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard ($71.88 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 8 GB (2 x 4 GB) DDR4-2800 Memory ($48.98 @ Newegg)
Storage: Western Digital - RE4 500 GB 3.5" 7200RPM Internal Hard Drive ($21.50 @ Amazon)
Video Card: Gigabyte - Radeon RX 570 4 GB Gaming 4G Video Card ($119.99 @ Newegg)
Case: Corsair - Carbide SPEC-04 (Black/Red) ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply ($37.98 @ Newegg)
Total: $425.21
Generated by PCPartPicker 2019-04-13 12:00 EDT-0400
hang-the-9
I would suggest saving up some more, just the monitor/keyboard/mouse will cost you over $100, or near there for used basic stuff.
Reactions: Banned by Net
scandrews
37
You really won't be able to get that at the budget you have. The 580 used is going to cost you 125-150, and the CPU is likely going to cost 200-250. That's your budget, before you get to a case, PUS, MB, etc.
I'd look at the Ryzen 2200G with a B450 MB.
Here's a set up that is within your budget, with some flexibility
https://www.newegg.com/Product/Product.aspx?Item=N82E16819113480
You can replace the 2200G with the 2400 for another $55. That would still be within your budget, but be a better CPU as it's 4 cores/8 threads, where the 2200G is 4/4
