Need help building a Gaming PC.
Ivan775
Hey, I need help building a gaming pc and it has to stay more or less in the $600-$650 dollar range.
It has to include:the tower, monitor, and keyboard along with windows.
This will also be the first computer I will ever build so I have no idea where to start, I am pretty confident in my self to be able to put it together though.
(It will be used for Gaming and browsing the web)
Best I can do with $650: Should be able to game at high to max settings on this monitor
Monitor : Acer G185HAb Black 18.5" 5ms
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009262
Case:Rosewill Blackbone
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147023
Motherboard + CPU:AMD Phenom II X4 925 Deneb 2.8GHz /MSI 880GM-E41 AM3 AMD 880G HDMI Micro ATX AMD
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.700694
CPU Heatsink:COOLER MASTER Hyper TX3
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103064
GPU:SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
RAM:G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333...
Ivan775
I would prefer New Egg, Tiger Direct or Amazon but I'm open to other retailers.
I Live in Nevada, United States
morgoth780
625
Ok, it did end up a little bit over $650, but it's fairly challenging not to when you also need monitor and windows.
CPU: AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
Mobo: ASUS M4A78LT-M AM3 AMD 760G HDMI Micro ATX AMD Motherboard
Graphics Card: MSI N550GTX-Ti Cyclone OC GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Memory: Crucial Ballistix sport 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model BL2KIT25664BA1339
PSU: Antec Basiq BP500U 500W Continuous Power ATX12V Version 2.01 Active PFC Power Supply
Case: Antec Three Hundred Black Steel ATX Mid Tower Computer Case
HDD: Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
OS: Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Monitor: Acer G185HAb Black 18.5" 5ms Widescreen LCD Monitor 250 cd/m2 50000:1(ACM), 1000:1
Keyboard: IOGEAR GKM513 Black USB Wired Slim Keyboard
Total: $701.45
I'm fairly sure that PSU/mobo will work with everything else, but it would probably be worthwhile to check with some other people
kaweee
131
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231394
HDD + DVD Burner:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696142
PSU:Antec EarthWatts Green EA-430D Green 430W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371034
OS:Microsoft Windows 7 Home Premium SP1 64-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Keyboard:Rosewill RK-700M Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201039
Total 669.35 After shipping and a $15 rebate
If you absolutely can't go above $650
EVGA 550Ti would be a good subsitute
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130629
Would drop the total by $20
