As simon12 has suggested, the articles he's linked is a good idea (I also agree with the 670). But heres a run down of components anyway:
Case: Any ATX size case that you like - must be able house the following components. (Good brands - Corsair, Cooler Master, Sharkoon, NZXT, Thermaltake, Antec etc). This should help -
http://www.tomshardware.co.uk/picturestory/48-raidmax-agusta-eleven-hundred-storm-enforcer-kl04b-arc-midi.html
Processor (CPU): Intel i5-2500k or i5-3570k - if you have a little extra money but you dont want to Over clock, then go for the 3570k.
RAM: 8GB Corsair Vengeance 1600 DDR3 is a solid choice
Graphics Card (GPU): Nvidia GTX 670 (or if you want to save some $, then wait till August 16th for Nvidia to release the 660ti - should be a great GPU that will do everything youve asked)
Motherboard: Any Z77 Intel 1155 ATX board with 4 DIMM slots and atleast 1 PCI-E x16 Graphics card slot from brands such as Gigabyte, Asus, MSI or ASRock. Example -
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
Power Supply Unit (PSU): Probably the most important but most overlooked component of the lot. You need to use a reliable, stable power supply with enough wattage to power your components well. For a system with a 670 graphics card, then a 600watt PSU is a good idea. Good brands include; Corsair, Seasonic, Antec, Coolermaster. Example - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028, or if you have a little extra cash -
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Hard Drive: You will probably want to have atleast 500GB - go with a 3Gb/s SATA II HDD if you want to save a little money, but if you can fit it into your budget, go with a 6Gb/s SATA III HDD, itll be faster. Example -
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136314
SSD: Optional, but a very nice thing to have! They are essentially a small, more expensive Hard drive, but are extremely fast. Expect boot times of less than 20 seconds and very fast loading screens in games. Only get if you have the money. Example -
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233206
Operating System: Even though Windows 8 is just around the corner, it will most likely be best to stick with Windows 7 64bit. W8 is made for touch-screens and tablets, not desktop gaming.
CD Drive - If you cant afford to get a blue ray drive, then almost any $20 drive will do. Example -
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118067
