Need help building a gaming rig
maksat
9
Im going to use this pc mainly for gaming. I want to make sure, that all the components comply with each other. Any comments, suggestions or anything would be extremely helpful. Unfortunately my budget is only $1000 so Im trying to stretch it as much as I can.
My current layout:
CPU: Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
CPU Cooler: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Case: XCLIO Windtunnel Fully Black Finish 1.0 mm SECC Chassis ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103011
Power Supply: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Motherboard: ASUS P5Q-E LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131296
Graphics: SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
RAM: CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145215
HD: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
DVD-Burner: ASUS 22X DVD Burner with LightScribe Black SATA Model DRW-22B1LT
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135186
Before shipping: $1049.92
After shipping: $1095.97
Thank you for reading
xthekidx
Splendid
Dec 24, 2008
3,871
It looks pretty good. Here are some suggestions to cut down the price a little bit:
This mobo is as good if not better than the one you are looking at and cheaper, comes bundled with the processor:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.182077
Case, free shipping with promo code: EMCLRLN22. This case is very well cooled and quite spacious. If you want, you can add up to 4 more 120mm fans to it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Good fans:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185058
Get a free eSATA cable so you can use eSATA if you want to:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.175916
There is no reason to get faster ram on the P45 chipset, you will see almost no gains for it. Get fast cheap ram like this. This will probably be faster because of the lower timings and you won't have to wait 8 weeks for the rebate to make it the same price:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231219&Tpk=g%20skill%20hk
Get that cooler with a backplate, its essential:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029&Tpk=s1283v
maksat
9
Wow thank you very much for the great response sir, you've listed everything so detailed. I was very interested in your cpu+mobo combo choice.
I have narrowed them both down and I have one question:
Expansion slots:
PCI Express 2.0 x16 | 2 x PCI Express 2.0 x16 slots, support ATI CrossFireX technology, at x8 link
(black at max. x8 link)
PCI Express x4 | 1 x PCI Express x16 slot at max. x4 link(black)
PCI Express x1 | 2
PCI Slots | 2
Features: Crossfire
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
Expansion slots:
(one running at x16 model, another one running at x8 model)
PCI Express x1 | 3
PCI Slots | 2
One of the features on the Asus board is the crossfire option which is very important for me. I assume that GIGABYTE board is not crossfire ready. Please let me know you think and thank you again for you response.
maksat
9
roger that guys im going with your suggestion, and buying everything this week!! Thank you very much for you help!!!!!
