I'm buying a new PC soon, but I have no experience with building one on my own (choosing parts and building it) what-so-ever, so after some research and I came up with this parts:
-Intel Core i7-3770S
-Cooler Master Vortex Plus 54.8 CFM Sleeve Bearing (CPU Cooler)
-MSI B75MA-P45 Micro ATX LGA1155 Motherboard
-Corsair Vengeance 4GB (1 x 4GB) DDR3-1600 RAM Memory
-Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
-MSI Radeon HD 7870 GHz Edition 2GB Video Card
-Fractal Design Core 1000 Cases, Black
-Cooler Master Elite 460 RS-460-PSAR-I3 460W ATX12V V2.31 Power Supply
-Lite-On iHAS124-04 DVD/CD Writer
But, some time ago, I talked to a close friend of mine that works in a computer store and he said four things to me:
-First: He said that micro ATX motherboards aren't recommended for gaming PCs because they warm up really easily and recommended buying an ATX full tower motherboard;
-Second: The power supply that I'm using isn't going to give me enough wattage and the PC would turn off by itself when I'm playing;
-Third: That instead of using a power supply from cooler master, I shoud use a Zalman power supply.
-Fourth: The next Generation of Video Cards is coming really soon, so my PC will be obsolete in no time.
Now here is the thing: I'm going to the USA in two weeks from now, and since everything in my country (Brazil) is expensive, I'm going to use this oportunity to buy all my PC components in there, but since that talk with my friend, I'm really unconfortable with my build, and now I want to change the Motherboard and the power supply of my build but I dont know what to use and I don't think I'm going to the USA again any time soon, so I cannot wait the next gen of video cards to get released.
Also, I need something that fits my budget that is something between 700-900 dollars.
Now here is the question: Do you guys thing that this build is an efficient one for my budget? And what motherboard and Power Supply should I use?
More Info:
Approximate Purchase Date: in two-three weeks
Budget Range: 700-900 dollars
System Usage from Most to Least Important: Gaming and School work
Are you buying a monitor: Yes, but in Brazil.
Do you need to buy OS: Yes
Preferred Website(s) for Parts: None
Location: Campinas/SP, Brazil, but buying in Boston, USA
Parts Preferences: No brand preference
Overclocking: No
SLI or Crossfire: Not sure what this is...
And Most Importantly, Why Are You Upgrading: The motherboard from my old PC literaly fried and since is an old PC, I'm buying a new one.
P.S. (Since I'm from Brazil, naturaly, English isn't my native language so forgive me for any grammar or spelling mistakes.)
More Info:
Overclocking: No
