Hey all!! I have been around here lurking for a while now, and I have been looking at building a PC. I have a list of components that I would like to use to build a gaming PC and I wanted to know if the hardware is both compatible and up to spec in terms of not being excessive or under powered. I really appreciate any wisdom you all could lend me. (this is made to support 3-4 monitors for both gaming and work).
Also, I would like opinions on a case, I would like a full tower, i am not looking to over clock, so I am not sure if I would need liquid cooling or if that was over kill? Thanks again!
Case: Azza Genesis 9000B Full Tower Case, Black (CSAZ-9000B)
CPU:Intel Core i7-4770K Quad-Core Desktop Processor (3.5 GHz, 8 MB Cache, Intel HD graphics, BX80646I74770K)
Motherboard: MSI ATX DDR3 2600 LGA 1150 Motherboards Z97 MPOWER MAX AC
Memory:G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM 1600 (PC3 12800) Desktop Memory F3-12800CL10D-16GBXL
Videocard: 2 x Sapphire Radeon R9 280X 3GB GDDR5 DVI-I/DVI-D/HDMI/DP Dual-X OC Version (UEFI) PCI-Express Graphics Card 11221-00-20G
Power Supply: Thermaltake Toughpower Grand 1050W TPG-1050M SLI & CrossFire X Ready ATX12V 80PLUS Gold Active PFC ATX 1150 Power Supply TPG-1050M
SSD: Samsung Electronics 840 EVO-Series 250GB 2.5-Inch SATA III Notebook Kit Version Internal Solid State Drive MZ-7TE250LW
HDD: WD Velociraptor WD1000DHTZ 1TB 3.5" SATA Hard Drive
Optical: Asus Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-Ray Drive (BC-12B1ST)
Screen: 3 x Samsung 27-Inch Wide Viewing Angle LED Monitor (S27D390H)
Edit: Budget of 2,000-2,500 would prefer closer to 2,000 otherwise the wife may disown me
