i want to run Fortnite at 240fps ( i will have a 240 hz monitor) and my budget is £1,300 (i will run everything on low) i dont care about excessive RGB , (also please use a SSD in this build ) , Thank you
Hmm, would probably wait a week just on a "to see" about 3xxx, but if right this moment I would put most of the budget to a nice RTX GPU. Round out the build with a Ryzen 5 and some fast memory and you should be there.
wait for the ryzen 3rd gen to hit markets and get reviews, ryzen 5 should do the job paired with RTX 2060 or 2070.
how ever if you not in hurry nvidea will launch new GPUs soon
