I am looking for a gaming tower that is small and portable but has the same abilities as a full sized gaming tower. i am in no way tech savvy so if you guys start saying stuff like i78sk56g motherboard (i know thats not a real one) i will have no idea what you are talking about, but i am willing to learn. so if you do decide to help me all i ask is that you explain it to me like you would a child. all i know is that i would like to play games to the full extent. for too long i have had to turn the settings down to low and still have trouble playing. an example game as of now that i have trouble with is Fallout 4. i also like to do graphic design and stuff with Photoshop, 3D effects, etc.. so if you could incorporate that stuff into the build as well then that's awesome
i have an idea for a case that is suitable for portability...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345066&cm_re=bitfenix-_-11-345-066-_-Product
If anyone can find something better than that (still easily portable) than by all means please suggest it. for the graphics card i DO NOT WANT AN AMD RADEON. i have always gotten those without my choice (my father) so please stay away from them. my budget for this can go up to $1500, but i would like to keep it close to $1000 if at all possible.
If anyone does decide to help me then i, from the bottom of my heart, thank you. from one gamer to another. its been a long time since I've played a PC game without frame drop or crappy graphics. also just to add this will be my first desktop ever so a monitor is also needed as a suggestion. again i an not savvy so i know nothing about monitors as well.
