Hey guys, I'm looking for a build that will be able to handle BF3 on high/max settings at 1080p. I'm not looking to spend more than $1100.
Let me first off say that I won't be building until December. I would like to know if I selected the right parts for the job and if I should wait for new parts in these next few months. I've only listed the mandatory parts, I don't need to ask about an optical drive because I'd just get any one.
Right now I'm looking at this deal:
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
BYTECC 6 ft. 18AWG Power Cord w/ 3 Conductor PC Power Connector – Black Model POWERCORD-6K
GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard (
Antec EarthWatts EA-650 GREEN 650W ATX12V v2.3 SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.722562
My only concern with this combo is the psu is only 650W. Right now I am going to get a 6950(and flash to a 6970) but in the future I could get another hooked up to xfire and oc'ed and flashed as well. So I would be using dual oc'ed bonafide 6970's.
It depends really if a single 6950 can run BF3 at high. Since the system requirements aren't out, no one will know, but I'd like to have an idea in mind.
Also do should I used some sort of cooling system as well?
I have so many questions, this is my first build so I am curious to see what will work out best. Again if you can give me an idea of what kind of gpu would be the best choice for ultra settings in BF3, and I'll stick to that. I think that the 6950's are the best bang for buck because you can flash and xfire them.
But I should most likely for get about trying to find parts now and just wait till black friday comes around the corner. Right now its pointless, but I still like to have an idea in mind.
