Need Help Building Budget Computer
ryan8989
66
i have about £310 Max to spend, i already have a XFX HD 6870 which i plan on using in a new computer that i'll have to build or comes built i need suggestions whats a good gaming computer for this budget also got to remember i need a PSU to go with this Graphics Card and i live in the UK any help would be appreciated, thanks :)
Rammy
What do you need to buy with the £310? Everything other than graphics card? Do you need an OS included?
These questions are going to have a massive bearing on how much money you have to play with.
If you already have a case or HDD you can use, then your budget can reach to a basic i5 setup.
CPU: Intel Core i5-3450 3.1GHz Quad-Core Processor (£140.11 @ Amazon UK)
Motherboard: MSI B75MA-E33 Micro ATX LGA1155 Motherboard (£42.90 @ Scan.co.uk)
Memory: GeIL Enhance CORSA 8GB (2 x 4GB) DDR3-1600 Memory (£30.23 @ CCL Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£57.96 @ Amazon UK)
Case: Antec Three Hundred Two ATX Mid Tower Case (£50.37 @ Amazon UK)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£49.98 @ Novatech)
Total: £371.55
(Generated by PCPartPicker 2012-12-13 15:11 GMT+0000)
I know it's over budget, but if you have items that will suffice, it's likely to be the best performance in your price range.
An alternative is to drop that i5 to an i3 3220 which shaves £50 off the budget.
