I am looking to purchase a custom build roughly 2000$ gaming PC. I have configured one on cyperpowerpc :
Gaming Chasis: Raidmax Vampire w/ USB 3.0, Hot Swap HDD Dock, Fan Control, 1x 200mm fan, Side Panel Window (White Color)
Internal USB Expansion Module: Internal USB Expansion System + Bluetooth & Wireless N Modules
Extra Case Fans: Maximum Corsair AIR Series AF120 Performance Edition 120MM High Airflow Case Fan (Maximum Mix ENERMAX TB SILENCE 140mm+120mm Performance cooling with a low-noise profile Fans)
Noise Reduction Technology: Sound Absorbing Foam on Side, Top And Bottom panels, and more(2) ****Not sure if this is needed****
CPU: Intel® Core™ i7-4820K Quad-Core 3.70 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified) OR Intel® Core™ i7-4930K Six-Core 3.40 GHz 12MB Intel Smart Cache LGA2011 (All Venom OC Certified)
CPU / Processor Cooling Fan: * Cooler Master Hyper 212 EVO CPU Cooler w/ PWM fan - Efficient Cooling Performance
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: ASRock X79 Extreme4 ATX w/ Xfast LAN, Charger, & USB, GbLAN, 3 Gen3 PCIe x16, 2 PCIe x1, 2 PCI ***Not sure if this is a sufficient motherboard***
RAM / System Memory: 16GB (4GBx4) DDR3/2133MHz Quad Channel Memory (Corsair Vengeance)
Video Card: NVIDIA GeForce GTX 650 1GB GDDR5 PCIe 3.0 x16 Video Card (Major Brand Powered by NVIDIA) ****I think the motherboard supports dual video cards, not sure if I should go with dual video cards...****
Power Supply: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready ***Purchasing this powersupply because it is on special on the website for the same price as a 350W one***
Hard Drive: 120 GB Kingston HyperX 3K SATA-III 6.0Gb/s SSD - 555MB/s Read & 510MB/s Write (120GB x 2 (120GB Capacity) Raid 1 High Performance with Data Security)
Hard Drive Cooling Fan: Vigor iSURF II Hard Disk Drive Cooling System (3 x Systems)
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO **not sure how important a good sound card is**
Internal Network Card: Intel Pro Gigabit 10/100/1000 Network Card
Internal Wireless Network Card: GIGABYTE GC-WB867D-I 802.11AC Wi-Fi up to 867 Mbps + Bluetooth 4.0 Combo w/ Dual Antenna PCI-E Adapter
USB Hub & Port: Internal USB 3.0 4-Port Hub
Operating System: Microsoft® Windows 7 Ultimate (64-bit Edition)
Roughly totaling $1860
I want to be able to stream at a high quality while not losing in game performance. I also would like to be able to play the newest releases on the highest quality. Just curious if this is optimum, I plan to buy it within a month.
I have absolutely zero experience purchasing gaming PC's. And my knowledge on parts is based off of what a few friends have told me. I have done some things that i am not sure are optimal so any advice at all is appreciated.
Thanks!
Thanks!
