[SOLVED] Need help building first PC
Mar 31, 2019
5
Hey Folks,
I was wondering if anyone could help me get a set up for building my first gaming PC.
I don't really know much about it at all.
I was looking to spend about $950 USD
I want to be able to run most games at decent settings to look good.
I mostly will plan to play siege, red alert, C&C, starcraft and probably some other high demanding games in the future.
I want something that won't be useless by the end of the year.
Do you need the peripherals or monitor?
I would use the Ryzen 1600 as a placeholder for 3rd Gen (More cores/threads and a much higher clock speed). Can be found for $80 at Microcenter.
https://www.microcenter.com/product...-am4-boxed-processor-with-wraith-spire-cooler
Tower Only.
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor ($79.99)
CPU Cooler: Cooler Master - Hyper 212 Black Edition 42 CFM CPU Cooler ($31.00 @ B&H)
Motherboard: Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard ($138.88 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8...
Tower Only.
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($99.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive ($69.95 @ Adorama)
Video Card: Zotac - GeForce GTX 1660 Ti 6 GB GAMING Video Card ($278.99 @ SuperBiiz)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($63.23 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply ($75.31 @ Amazon)
Total: $837.34
Generated by PCPartPicker 2019-03-31 17:25 EDT-0400
(Aftermarket cooler is much quieter then stock one) This build would handle 1080P/1440P gaming well.
Everything.
Motherboard: Asus - PRIME B450-PLUS ATX AM4 Motherboard ($109.89 @ OutletPC)
Video Card: Zotac - GeForce GTX 1660 6 GB GAMING Video Card ($219.99 @ Amazon)
Monitor: Dell - SE2717H 27.0" 1920x1080 75 Hz Monitor ($142.50 @ Adorama)
Keyboard: Cooler Master - Lite L Wired Gaming Keyboard w/Optical Mouse ($55.85 @ OutletPC)
Speakers: Logitech - Z213 7 W 2.1ch Speakers ($26.19 @ Amazon)
Total: $942.89
Generated by PCPartPicker 2019-03-31 17:31 EDT-0400
Reactions: ItsJustMax
Ok so the second build I posted. I updated the build with a better monitor, 1080P/75hz/IPS and supports Freesync so you should be able to use it with the Nvidia GPU with newer drivers. Also changed the motherboard to better suit your budget.
Will this be able to run something like metro exodus at high settings? I don't plan on buying this game but would it be able to run something like that at like 4k?
