Need help building gaming rig.... (mobo?, liquid cooling?, etc)
saranghaes2
69
not sure if this is in the right section, sorry if it isn't but
alright, so basicly im deciding to maybe build my own desktop... i wont care about the cost. i care about the performance and kind of noise. also looking at how hot/cold it will/can be. so far all i have is this to run on.
Case: is def. full-tower... i just dont know which one to get yet... suggestions please for this as well~
Processor: Intel® Core™ i7 980x Extreme Six Core Processor (3.33GHz, 12MB Cache) (heard theres a way to make it 12 cores? im new to this..)
Operating system: Genuine Windows® 7 Ultimate, 64bit, English
memory: not sure weather to get 6 gb sticks or 12 gb sticks.... and if i should get 2 or 3/4
hard drive: 512GB Raid 0 (2x 256GB Samsung Solid State HDDs (if theres a better hard drive suggest please~ must be SSD) (solid state)
Video card: Dual 2GB GDDR5 ATI Radeon™ HD 5970 CrossfireX™ Enabled or Dual 1.5GB GDDR5 NVIDIA® GeForce® GTX 480 - SLI Enabled??? (if theres a better one again~ please suggest)
optical drive: Slot-Loading Dual Layer Blu-ray Burner (BR-R, DVD+-RW, CD-RW) (again suggest better ones please?)
sound card? (is it needed...):Creative Sound Blaster X-Fi Titanium (suggest?)
and of course the optional Killer Xeno™ Pro
Im wondering which liquid cooling system i should get and which motherboard would be best to handle all of these... i know its a lot to ask but i really really wanna know and it would be awesome if u could share your knowledge. (btw if im missing stuff tell me and ill edit it in... my bad in advance ^^;;)
thanks a bunch
ares1214
Splendid
Dec 15, 2009
4,471
90
first off, is this a complete build, or do you already have certain parts? what are your needs? im assuming you dont have a budget. country of origin? without all that, i cant do too much, but heres some pointers:
CPU: depends if you want future proofing or not. might want to get the xeons for the sr2
GPU: id wait for the gtx 475, or in the mean time get a few 470s or 2 5970s. maybe the Ares.
OS: good
RAM: you can more or less get a max of either 24 or 48 gigs (conventional board or sr2)
HDD: there are better ssd's out there, like these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227552
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148349
the rest i need the top info for.
ares1214
Splendid
Dec 15, 2009
4,471
90
also, what is your building expertise and experience with an lcs loop? if those arent high, the best system might be one from cyber power or digital storm, however of course i recommend to build your own.
saranghaes2
69
if the gtx 475 is better than what i've chosen then i guess ill do so. im going to try to get probobly 48 gigs of ram.
I'm in Canada, my needs are to run any game on the absolute best settings and maybe be able to record with 60fps plus (basicly very good performance)
im trying to make a complete build... im kind of a newbie at this but im very eager to learn. those are basicly what i need. i expect to be keeping this for at least 8+ years for myself.
Any more suggestions? i'd gladly appreciate it!
EDIT: i also wonder which power supply i should get... im aiming towards a 1k watt power supply, depending on what ill need.
coldsleep
2,475
98
If you could provide the info requested in How to Ask for New Build Advice, that would help a lot.
The i7-980X has 6 cores and it has hyperthreading which enables it to present 12 logical cores. Basically, each core acts like 2; I'm guessing that's what you're referring to. The i7-980X is complete overkill for gaming, you'll be fine with the i7-930 for about $770 less. If you really have the money to burn though, go ahead and get the 980.
With RAM, for an i7-9nn, you want to get 6, 12, 24 GB (multiples of 3 sticks). 6 is all you need for gaming, though.
For graphics, it really depends on what you're looking for. Are you more interested in 3D gameplay or extreme (5x1 or 3x2) multi-monitor setups? If 3D, I'd go with nVidia (with the caveat that I don't think 3D gaming is really going to be all that exciting for another few years), if big multi-monitor, go ATI.
The best 256 GB SSD out there right now is the Crucial C300, which ares also linked. You will probably also want one or two traditional hard drives for data storage.
Most people find that onboard sound is pretty great these days and don't need a separate sound card.
And really, the "gaming" network cards are a waste of money unless you plan to drag the box around to LAN parties. At best, they may be able to reduce your ping on your local network (thus a possible improvement for LAN parties). They can't do anything about the traffic once it hits your cable box or DSL modem or whatever. You'd be better off spending that money on a faster internet connection.
saranghaes2
69
thanks a lot for your advice, i really appreciate it. ill start off wit hthe "how to ask for new build advice"
APPROXIMATE PURCHASE DATE: from a month to 5 months. depends on what comes out in the time span as well.
BUDGET RANGE: no price range, go all out.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Multi tasking with lots of programs running, possible 3d 4d rendering, etc.
PARTS NOT REQUIRED: Mouse pad, speakers, 3d moniters (dont need 3d really, maybe later) and thats it i think
PREFERRED WEBSITE(S) FOR PARTS: i heard newegg is pretty good. Also, brand named sites are good too (example intel) more reliability.
COUNTRY OF ORIGIN: Canada
PARTS PREFERENCES: whichever u experts advise, ill research into it deeper and see which i want to choose. that would help me greatly.
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: whichever seems better, although i've heard crossfire is good.
MONITOR RESOLUTION: prefered to have the highest possible? (im going all out with this)
ADDITIONAL COMMENTS: if its possible to make it quieter without changing performance or heat problems etc please suggest. It would be nice to learn a lot more as im asking these things so go ahead and say little "tips" that could help me in the future, thanks!
ares1214
Splendid
Dec 15, 2009
4,471
90
if you are willing to wait 5 months, i would. sandy bridge and bulldozer will be making their debuts, and hopefull the nvidia 4xx lineup will be complete, and maybe some info in ati 6xxx series. its never good to wait for tech, as theres always more around the corner, but now IS a good time to wait it out IMO.
saranghaes2
69
srry to hassle u and stuff, but if i did wait til leverything came out, which would u recommend? u dont have to tell me if its ganna take too much of ur time. what you've told me is already a lot and i thank you for that.
ares1214
Splendid
Dec 15, 2009
4,471
90
its hard to say to be honest. not enough info is out on these things. however, if you wanted my educated guess, i think Bulldozer is the better buy. Assuming you buy new, bulldozer will have a good upgrade path on am3+ (if they follow history), and will be backwards compatible with am4 (maybe?). Also, at the time, intels sandy bridge will be on socket 1155. This is actually mainstream for them, and socket 1366 will actually be the highest performing all the way till Q3 2011. in Q3 2011, intel release the new socket, which 1155 wont be compatible with. Also, id say its fairly likely bulldozer will outperform sandy bridge to begin with.
saranghaes2
69
i really wish i knew more about what u were talking about Dx looks like i have to hit the books hard tomorrow.
I've also been wondering about the power supply... is Diablotek RPM Series 950W ATX PSU any good for what im building? or could i do better?
gerry410
577
5
HI, just wanted to suggest reading some of Tom's "do it yourself " builds. Thats what I did and its all working well. I pretty much followed the $1500.00 March 2010 build with a few upgrades and minus 1 video card due to my budget. I figured for my first build its a good safe "recipe" to follow.
If it's your first build I would also suggest watching a lot of you tube how to videos. Take peoples advise of what they think you should do with caution and get a lot of different opinions. Liquid might be risky for a first build but if you must take it slow and cautious. Good luck man. Your gonna feel great when you hit that power button and the machine purrs.
saranghaes2
69
I've chosen these 3 full towers and these 3 motherboards... i dunno which one i should choose. in terms of the tower, i want it to be easily cooled yet stylish.
all 3 motherboards support the core i have but i dunno whihc would be best for the rest of the stuff i have.
i also chose a power supply, tell me if u think its good enough please. thanks~!
Images
Chasis/cases: http://thermaltakeusa.com/Product.aspx?C=1303&ID=1423#Tab1
http://www.directron.com/vh600lbws.html
http://thermaltakeusa.com/Product.aspx?C=1445&ID=1418#Tab2
Motherboard: http://www.directron.com/rampageiigene.html
http://www.directron.com/rampageiiigene.html
http://www.directron.com/dx58so.html
Power Supply: http://www.directron.com/rsc0080gad3us.html
Also the cooling i chose: http://www.directron.com/cwch501.html
do i have to refill that one constantly? or can u just leave it? wondering about that too.
your replies will be much appreciated! thanks a lot guys
saranghaes2
69
my bad accidently pressed remove. man i love the chasis designs u chose! stylish and good for cooling!
Thx for the motherboard choice too, i've been trying to find something like this.
for power, i tihnk im wither ganna go iwth the first one or the third one... still deciding though.
Your the best help iv'e ever come across, enough for me to call u godly even x] you've inspired me to press on and study hardware even further thanks a lot!
ill try to combine everything ive got and then ill post it up later. your the best!
saranghaes2
69
lol if u would do that for me then i would feel guilty >_< but if u can i would also be extremely greatful.
sorry for the late reply :p i was hooked on final fantasy x >_< my friend gave it back and i wanted to play it badly
saranghaes2
69
lol i already told u everything xD ill post it again in here then.
case: http://www.newegg.com/Product/ImageGallery.aspx?CurImage=11-119-225-TS&ISList=11-119-225-Z01,11-119-225-Z02,11-119-225-Z03,11-119-225-Z04,11-119-225-Z05,11-119-225-Z06,11-119-225-Z07,11-119-225-Z08,11-119-225-Z09,11-119-225-Z10&VSList=11-119-225-V01,11-119-225-V02,11-119-225-V03,11-119-225-V04,11-119-225-V05,11-119-225-V06,11-119-225-V07,11-119-225-V08,11-119-225-V09,11-119-225-V10,11-119-225-V11&S7ImageFlag=1&Item=N82E16811119225&Depa=0&WaterMark=1&Description=COOLER%20MASTER%20HAF%20X%20RC-942-KKN1%20Black%20Steel/%20Plastic%20ATX%20Full%20Tower%20Computer%20Case
Supply power: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341028&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130289&cm_re=big_bang-_-13-130-289-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
HHD: around 3 or more of these http://www.newegg.com/Product/Product.aspx?Item=N82E16820148349&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
Video card: im ganna wait for the card u suggested for me. i think it was the GTX 475
Processor: intel i7-980x hex core extreme
OS: windows 7 ultimate
i think thats everything. am i missing something or do i have any non-compatible parts?
almost forgot im getting 12 or 24 gb ram sticks too.
Similar threads
