Need help building gaming rig.
MaxChasis
67
Hello, this will be my first time building a gaming rig, so I am a novice when it comes to picking parts. Take a look at it and tell me what you think.
- Is their any part that is to overkill/underkill
- Should I get sli 980. If not now then is my system good enough to support the sli?
- is overclocking hard to do, I have never done it.
- is this system good enough for 1440p?
I don't own a 1440p monitor (yet), is it worth it? I have a pretty cheap 1080p right now. If I should get one then could you recommend a brand?
Could you also recommend a good looking case that would fit this? I was think NZXT ca-ph410-g1 Phantom 410 Mid Tower USB 3.0 Gaming Case Gunmetal with Black Trim
Thank you so much for your time.
-Intel Core i5-4690K Processor 3.5 GHz LGA 1150 BX80646I54690K
-MSI ATX DDR3 2600 LGA 1150 Motherboards Z97 GAMING 5
-MSI Graphics Cards GTX 980 GAMING 4G
-Corsair Vengeance Blue 8 GB (2X4 GB) PC3-12800 1600mHz DDR3 240-Pin SDRAM Dual Channel Memory
-Cooler Master Hyper 212 Plus - CPU Cooler with 4 Direct Contact Heat Pipes (RR-B10-212P-G1)
-Samsung 850 EVO 120GB 2.5-Inch SATA III Internal SSD (MZ-75E120B/AM)
-Seagate 1TB Desktop HDD SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive (ST1000DM003)
-EVGA SuperNOVA 650G1 650W ATX12V Power Supply 120-G1-0650-XR
Good build but you could go with 16GB of RAM and 1440p is nice but kind of expensive and the NZXT Phantom 410 would work but I would recommend a bigger case and SLI is not needed in the build right now and SLI depends on your motherboard.
