Need help building my new gaming pc
Ad4m_p
Commendable
Mar 12, 2016
4
Ok so my current computer is made up of prehistoric components and is just not possible to play games on so I have decided to build a new gaming pc that can run all the latest games specifically(black ops 3) at high graphic settings, money is not an issue so I would like to build the best possible rig I can
So my question is what would be the best route to go for
Intel or AMD based computer?
Is there any specific builds or what parts I should use one could recommend
Yeah, if your budget is that high, I would suggest those but no six core, go for 8 core, water cooled maybe (if you had extra or just use a lot, and I mean a lot of fans), but I stick with the 9 390x, they are a really great gpu
Whats your budget? I would suggest AMD cpu (cheaper but in my experience preform just as well), an dual msi r9 390x, msi 970, 16 gb ddr3 ram (I use hyper x 1833 hz), and a decent psu that can support all of that
Just some suggestions
Well I would say my budget will be no more £2000. I just want to build a best possible system that I can, just don't want build a computer to find out that it can't run my games well. Thanks I will take a look at the components you listed
