Need help building Pc
krinamite
19
I decided recently to get into Pc gaming, and for this I need a good pc. After looking at youtube videos, forums and websites, I decided that I should just ask other people.
My budget for my Pc is $600 (no more). With this budget I know I'm not going to be able to get the "best" Pc but I'm just looking to play games like Overwatch and that generation on good fps and decent graphics. I have three builds that I researched and I would love if you guys could give me any input or comments on them. If I should change this component here or add more RAM etc. If I should get a completely new build then, please go right ahead and link or outline the build in the comments. Including the title and total amount.
Note; when you reply to one of my builds please label which one e.g.
1st build: I noticed that
Here are my builds:
1st build
CPU: Intel - Core i3-6100 3.7GHz Dual-Core Processor
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
RAM: G.Skill - Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive
Case: Corsair - 300R ATX Mid Tower
Power Supply: EVGA - 450W 80+ Bronze Certified ATX
Need a Grahpics card and a motherboard. Case fan?
2nd build
Motherboard: ASRock - B150M Pro4V Micro ATX LGA1151
RAM: Corsair - Vengeance LPX 8GB (1 x 8GB) DDR4-2400
Graphics Card: Gigabyte - Radeon RX 460 4GB WINDFORCE OC Video Card
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Case: Fractal Design - Core 1100 MicroATX Mini Tower
Power Supply: EVGA - 450W 80+ Bronze Certified ATX Power Supply
Should I get a CPU cooler? Case fan?
3rd build
CPU: Intel Pentium G4560 3.5GHz Dual-Core
Motherboard: MSI B250M PRO-VD Micro ATX LGA1151
RAM: G.Skill Aegis 8GB (1 x 8GB) DDR4-2133
Graphics Card: MSI GeForce GTX 1050 2GB
Storage: Kingston SSDNow UV400 120GB 2.5" SSD
Case: Azza Cosmas ATX Mid Tower
Power Supply: EVGA 430W 80+ Certified ATX
Case fan: Rosewill RNBF-131209 59.8 CFM 120mm
Any feedback is appreciated thanks :)
The 430w is a poor quality version. Here is a new build with an CXM good quality power supply. It can handle upto a GTX1060. Given its 600 canaa prices you can only get a 1050ti. The full ATX version is much higher price so get the Micro instead. Leave off the HD I picked if you already got the used one.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($139.25 @ shopRBC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($89.50 @ Vuugo)
Memory: G.Skill - Ripjaws 4 Series 8GB (2 x 4GB) DDR4-2800 Memory ($79.99 @ Memory Express)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard...
This will blow away all yours with a real quad core and a 1060. For $600 you should put off a SSD and add it later when you get about $100 for a crucial 300mx 275GB or Samsung 850 250GB.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($109.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($61.98 @ Newegg)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory ($82.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($46.88 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 3GB 3GB Windforce OC Video Card ($216.89 @ SuperBiiz)
Case: Raidmax - ATX-502WBG ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply ($32.98 @ Newegg)
Total: $581.70
Generated by PCPartPicker 2017-08-07 11:55 EDT-0400
Thanks for the feedback it seems really good. Do you mind linking the pc build list please Thanks :)
Thanks 😀
Sorry to bother you again but do you know the fps I would get on max graphics in games such as Overwatch, Gta V and next-gen games?
Finding a ryzen 1200 review is hard but one with a 1060 3gb isnt possible. The R3 1200 tho overclocks the same as the 1300x so these benchmarks should give you an ideal. The 1080 used should push about twice the FPS of the 1060 so about half. At stock the 1200 should run about an equal to the 1400 in GTA5.
aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS9aL0wvNjk1OTM3L29yaWdpbmFsL2ltYWdlMDAyLnBuZw==
Overwatch must use more than 4 threads so the R5 1400 pulls ahead. Overclocking the 1200 tho should get near the i5-7400.
Could I change the Power Supply to this: EVGA 430 W1, 80+ WHITE
430W https://www.amazon.ca/EVGA-WHITE-Warranty-Supply-100-W1-0430-KR/dp/B00H33SDR4/ref=as_li_ss_tl?ie=UTF8&qid=1487386984&sr=8-1&keywords=EVGA+430W&linkCode=sl1&tag=techsourceyt-20&linkId=f9f5b7be4509e412481dfebfe068a2d9
Elbert I just realized that since I live in Canada the prices are higher plus shipping so everything actually costs $818 after tax. That's $218 over my limit so thanks for your help but I guess I won't be able to do it.
I was wondering if you could maybe help me find a different graphics card because the one you linked my has shipping of $60 and the case is $100 so if we do that the total price is $718.
I'm buying a used 1Tb Seagate Hard drive for $40 and I do want to keep the Motherboard and CPU.
So is there a build where I keep those two things but have a different GPU, Case, RAM all around $600? Im going to get the power supply that I mentioned to you in the other comment as it's $45 here and the cheapest one.
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.95 @ Vuugo)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card ($198.42 @ Amazon Canada)
Case: Xion - XON-310_BK MicroATX Mid Tower Case ($29.99 @ Newegg Canada)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.98 @ NCIX)
Total: $637.08
Generated by PCPartPicker 2017-08-08 15:30 EDT-0400
Elbert I've actually been thinking of buying a Dell Optiplex then a Graphics Card and Power Supply. I came across a great deal on ebay but said it only shipped to the US. However, when I selected US and put in my Canadian Postal Code It said shipping to CA, *insert postal code* Shipping Service USP. Yet right under it the seller dosent offer international shipping.
Here is a photo
http://imgur.com/a/k2oAz?
I think I'm going with this build instead:
Second hand DELL 7010 contains:
CPU: i7-3770 3.4 GIG
RAM: 2X4 DDR3 8 GIG RAM,
HARD DRIVE: 1TB HDD 250 GIG HDD
GPU: Gigabyte GeForce GTX 660 Ti
PSU: EVGA 500B 500W 80 Plus Bronze
I got all these off ebay except for the PSU. Since I bid on them all of this cost me $271 after tax and shipping.
