A Anthony Santiago Honorable Jan 5, 2014 31 0 10,530 Dec 19, 2015 #1 I'm looking for a case that will fit my twin frozr gtx 760 card and evo 212 fan. My budget is around 60 my friend offered me this Case for 60 but I read that my fan won't fit http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265
Solution Brandon- Dec 19, 2015 Anthony Santiago : My motherboard Is the Asus M5A99X EVO R2.0 these cases look great. I'm probably going to go with the first choice since it's highest rated Yes, its a very good case, also the case that _skittle_ suggested, the Define S is also a very good case, especially for water cooling.
Brandon- Reputable Aug 1, 2015 322 0 4,960 Dec 19, 2015 #2 Anthony Santiago : I'm looking for a case that will fit my twin frozr gtx 760 card and evo 212 fan. My budget is around 60 my friend offered me this Case for 60 but I read that my fan won't fit http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265 What model is your motherboard? If its an ATX board I suggest you look at this Case. http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153&ignorebbr=1 Upvote -1 Downvote
_Skittle_ Reputable Dec 2, 2015 115 0 4,710 Dec 19, 2015 #3 I would get either the S340 http://pcpartpicker.com/part/nzxt-case-cas340wb1 or the Define S http://pcpartpicker.com/part/fractal-design-case-fdcadefsbk (w/o Window) http://pcpartpicker.com/part/fractal-design-case-fdcadefsbkw (w/ Window) Upvote 0 Downvote
PsyKhiqZero Splendid Jun 1, 2008 3,171 0 21,960 Dec 19, 2015 #4 IMO Corsair Spec-01 is probably the best budget case around. The cooler and fan will fit in case np. http://www.newegg.com/Product/Product.aspx?Item=N82E16811139041&cm_re=corsair_spec_01-_-11-139-041-_-Product Upvote -1 Downvote
A Anthony Santiago Honorable Jan 5, 2014 31 0 10,530 Dec 19, 2015 #5 My motherboard Is the Asus M5A99X EVO R2.0 these cases look great. I'm probably going to go with the first choice since it's highest rated Upvote 0 Downvote
Brandon- Reputable Aug 1, 2015 322 0 4,960 Dec 19, 2015 Solution #6 Anthony Santiago : My motherboard Is the Asus M5A99X EVO R2.0 these cases look great. I'm probably going to go with the first choice since it's highest rated Yes, its a very good case, also the case that _skittle_ suggested, the Define S is also a very good case, especially for water cooling. Upvote 0 Downvote Solution
