Hello,
my pc right now is:Intel core i5-4440 @ 3.10GHz,12 gb ram DDR3,gtx 1060 6 gb.
Now I have two asus vc239 monitors that are 1920x1080,and I'm looking to buy a third one.I would like to play on 2560x1080 resolution and 29 inch monitor.How would my gaming be then?Should I upgrade my cpu?I heard if you playon a higher resolution then the gpu takes more then the cpu,is that correct?
