Need help buying gaming monitor!
treyt22
21
Hey guys im a complete noob when it comes to choosing a monitor so can ya'll help me find a great GAMING monitor for around $150-200.
Here are my PC specs:
Videocard: (2)
ASUS EAH4850/HTDI/512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Prod [...] 6814121253
Motherboard:
GIGABYTE GA-X48-DS4 LGA 775 Intel X48 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] GA-X48-DS4
CPU:
Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Prod [...] 6819115036
Memory:
Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Prod [...] 6820220269
Operating System:
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
http://www.newegg.com/Product/Prod [...] 6832116488
Hard Drive:
Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822136131
Optical Drive:
SAMSUNG Black 22X DVD+R 22X DVD-R 16X DVD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/Product/Prod [...] 6827151173
CPU Cooler:
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Prod [...] U%2bCooler
PSU:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC
http://www.newegg.com/Product/Prod [...] 6817139006
Case:
LIAN LI PC-65B Black Aluminum ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811112040
Keyboard / Mouse
Microsoft 65X-00024 Black 104 Normal Keys 8 Function Keys USB Wireless Standard Optical Desktop 700 Mouse Included
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109022
Remember keep price around 150-200 but good quality GAMING monitor.
Does response time make a big difference? From 5 ms to 2 ms?
Anyways at your price range the best you can hope for is a 19" LCD.
if you are going for a crossfire setup with two video cards you need to be using a 24" lcd or bigger which is more than your price range. the reason being that crossfire and sli is only worth using if you are at very high resolution 1920x1200 or higher, otherwise the performance gain from dual video cards is minimal. if you just want a 22" moniter i recommend using just one 4850 and picking up a samsung 22" i have one of those they are great, the resolution was 1680x1050. the moniter i'd recommend for the setup you listed is the hanns g aka hannspree 28"(27.5" viewable) it's about 500$ so it's far beyond your budget, but i have one of them and i can tell you it is the best money i have ever spent on anything computer related. also be aware that many lcds will have stuck pixels you will have to "massage" on a bit to get them working(google for info). on the response time, lower is better, especially for gaming, if the response is too high aka slow, you will have "ghosting" in games. btw that is a nicely spec'ed system, it is almost exactly what i would get if i were building a new one right now(i'd get e8400 instead of e8500, it's 30$ or 15% cheaper and only 5% lower clock, 3ghz vs 3.16, and it will overclock great with that motherboard).
