[SOLVED] Need help buying laptop for school
What are you going to use this for? If you aren't gaming, i'd suggest a laptop without dedicated graphics to improve battery life. If you are gaming, the MX110 included really won't cut it, so id suggest upgrading to a laptop with a better dedicated GPU.
https://www.elkjop.no/product/data/barbar-pc/32315/lenovo-ideapad-s145-14-barbar-pc-sort
Of the 2, this is the one I'd go for. I would avoid the other one since it only has 4gb ram.
I went for this one!
