Archived from groups: alt.sys.pc-clone.compaq,alt.windows98 (More info?)
A week or so ago my Presario Model 7478's hard drive began to fail. I had
gotten a message that the disc detected that failure was imminent, and I
bought a new hard drive. The new drive is a Seagate 80gb drive, whereas the
factory installed drive was a 30gb Maxtor.
I had checked on this group and was told that the Quick Restore CDs that
came with the computer could be used to set everything back up. That does
not seem to be true. The QR discs give me an error as the look for Drive "N"
and the set up aborts. From what I can see the Autoexec file on the CD sets
a path of "N:\CPQS\QR". It then tries to read files out of that directory,
but since the new drive has none of that on it - I am stuck.
I put the old drive back in and made the new drive the second disc drive.
That is the only way I could ask for help here. I called Compaq Support and
after a series of misunderstandings was told that I needed to purchase the
hard drive from Compaq and they would send the QR discs made for the larger
drive. I don't have Windows 98 on a separate CD and sure don't have the
other software on the QR discs.
My first problem was that the QR would not load and format the drive, like I
hoped it would, so I used FDISK and FORMAT to do that.
I am thinking that MAYBE the QR discs are looking for the same size of C and
D drives (24.5 GB C drive and a 3.36 GB drive D), the QR discs will work. I
could put the rest of the new drive into a drive E. But that is only my
theory and so far I have not been right too often about this. LOL
I would appreciate any help with getting the QR discs to work on a new drive
that is larger than the factory installed drive.
Thanks!
Steve
Thanks!
Steve
