Need help, can't connect to Wi-fi
ArkFan192
18
I've search for lots of solutions for my Huawei P8 Lite, I know this website is mostly about computers but I don't know anywhere else to go.
I had to clean all data and reboot my phone because I couldn't use gps and I wanted to play Pokémon GO 😛 after I did that the gps works fine but the wi-fi is way off I have to be touching the router for it to connect to it and if i go away even for 50 cm or 1 m it says access denied and I cant use it. I tried reboot it a second time and It just didn't change anything.
Please help me...
I have the same problem like this , today i went to huawei customer care they said to me that this problem is not only in your phone but all the models of p8 lite if you have warranty left then they will replace your cell with new one cause new one doesn't have that problem , it's the problem of motherboard you can't fix it only the customer care will fix this problem this isn't the software issue it's the hardware issue
