[Need help] Changing old for a new for gaming
HawK3yLV
11
Hi,
I recently saw that some newer-end games seem to lag on my pc, like Arma 2 or Diablo III. Also my pc crashes about 3 times a day ( Blue screen: Memory-management ). My CPU jumps allot (~5%, ~50%, 100%). So i though i should change my pc components as well as buy new ram cards, because of that annoying blue screen. Although i ran into a few problems...
My motherboard is M3N-H/HDMI which has AM2+ and i haven't seen any new components that would be compatible with my motherboard. Also if i changed my motherboard wouldn't i need to change everything else too? Isn't it cheaper just to buy a new pc? I don't really know, so i'm asking for an advice.
Here's what i have right now:
Motherboard: M3N-H/HDMI AM2+
Processor: AMD Athlon 64 X2 Dual Core 6000+ 3.1 GHz
RAM: 6 GB (4 slots, DDR2 each, 2 + 2 + 1 + 1 GB)
Gfx Interface: PCI-Express
GPU: GPU215 (NVIDIA GeForce GT220)
*EDIT *
PSU: ~600W
HDD: 921 GB
Thanks anyway :)
Just tell budget and we suggest best build for that price.
And sure let us know if you save PSU and case and what they are.
This is Intel build. and AMD is maybe cheaper.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($219.99 @ Amazon)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler ($49.99 @ Amazon)
Motherboard: Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard ($159.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($63.75 @ Newegg)
Storage: Sandisk Ultra Plus 256GB 2.5" Solid State Disk ($159.99 @ Amazon)...
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($88.34 @ OutletPC)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card ($305.91 @ Newegg)
Case: Fractal Design Define R4 (Arctic White) ATX Mid Tower Case ($94.99 @ NCIX US)
Power Supply: Rosewill Lightning 800W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($109.99 @ Newegg)
Total: $1227.94
(Generated by PCPartPicker 2013-11-05 09:21 EST-0500)
your cpu is a pile of junk...................so is your video card................ and you're trying to play what?.............. cmon. the best on the existing board would be a 965 quad core( if you can still find one ) and maybe a 2gig 7850/7870?
i see with the right BIOS you can run a phenom2 6core........... but wouldn't waste my money on that...............
otherwise, give budget as said earlier...
umm, CS:GO works perfectly on high resolution, btw i bought some of my current parts about a year ago, so i wouldn't say they're that bad
you really need to reassess that....................... the processor is way old and the graphics card is for watching movies........... if the person selling you that machine told you it was a good gamer.............. maybe back in 2005..........
