PCNERD
Hello, I am planning on building a computer. Are these parts compatible? Thanks!!
NZXT Guardian 921 RB 921RB-001-RD Black SECC steel chassis ATX Mid Tower Computer Case
Model #:921RB-001-RD
Intel BOXDH67CLB3 LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:BOXDH67CLB3
XFX HD-685X-ZDFC Radeon HD 6850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Model #:HD-685X-ZDFC
Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
Model #:BP550 Plus
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
Model #:BX80623I72600K
Kingston FCR-HS219/1 19-in-1 USB 2.0 Card Reader
Model #:FCR-HS219/1
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
Model #:F3-12800CL9D-8GBXL
Western Digital Caviar Black WD1502FAEX 1.5TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WD1502FAEX
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor
Model #:VH242H
Logitech MX 518 8 Buttons 1 x Wheel USB Wired Optical Gaming Mouse
Model #:931352-0403
Logitech C210 1.3 M Effective Pixels WebCam
Model #:960-000617
HP 24X Multiformat DVD Writer Black SATA Model 1260i
Model #:HP 1260i
Microsoft Windows 7 Home Premium
Rosewill RNX-N300X PCI Wireless Adapter
Model #:RNX-N300X
EVERCOOL RSF-14 140mm Case Fan
Model #:RSF-14
ARCTIC COOLING Arctic Cooling MX-4 AC-MX4 4 gram (g) All-Around Thermal Compound
Model #:AC-MX4
Logitech S-220 17 Watts 2.1 Multimedia Speaker System - OEM
Model #:980-000023
Rosewill RTK-001 Premium Anti-Static Wrist Strap
Model #:RTK-001
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
Model #:CNPS9500 AT
And here are the links:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121508
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136793
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146069
http://www.newegg.com/Product/Product.aspx?Item=N82E16835119096
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134753
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121014
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166051
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116856
http://www.newegg.com/Product/Product.aspx?Item=N82E16832114007
http://www.newegg.com/Product/Product.aspx?Item=N82E16827140042
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150515
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104354
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109149&cm_re=microsoft_comfort_curve_keyboard_2000-_-23-109-149-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009255
http://www.newegg.com/Product/Product.aspx?Item=N82E16899261001
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220805
Approximate Purchase Date: (As soon as I know its compatible)
System Usage (light gaming, surfing the internet, watching movies, multitasking, has bee be speedy)
Preferred Websites for Parts: (newegg.ca, ncix.com)
I have carefully chosen these parts but if they are bad quality etc. please let me know.
Thanks again!!!
Please respond ASAP
PCNERD
Thanks for your reply, but what exactly needs work? Do some parts not work well together or is it just not a very good computer?
pepe2907
643
Like for example: Why do you buy a H67 based mobo, if you don't plan to use it's onboard grabhics solution? Buy a P67 for the same price of ~100$ - like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128487 - it's much better, packed with many more extensions...
Also - your i 2600 is an overkill for this system, go for a 2500 and find a better way to spend the rest of your money...
Etc. ...
PCNERD
Great thanks!! I'm planning on using heavier applications and programs in the future so i will probably keep the 2600. i know its overkill, the the other parts are cheaper to upgrade. (so eventually the caliber of the other parts will match the CPU) But the motherboard i will change. That's great! Any other suggestions? is it still compatible?
pepe2907
643
What heavier applications do you mean? I have some experience with certain types of heavier apps., maybe can help. Like : your 1080p monitor is not good for CAD or 3D, neighter it's good for photo and video editing. I may have some notices about your RAM. Your mouse is for gaming... Can't actually check all your components like coolers, sorry.
PCNERD
Is there a monitor that is $180 or less and good for:
Gaming (sims3 and need for speed etc)
Lots of video and photo editing
Some 3d modeling (google sketchup)
I plan doing some music production
Lots of multitasking
Thanks
PCNERD
Thanks for the replies! Are you positive the parts are compatible? I really don't want to have to return some parts across the border because the shipping is very expensive.
Latest posts
