Need help Choosing a GTX 960 card
Zahid Merchant
9
I'm stuck between the EVGA GTX 960 SSC and GIGABYTE GTX 960 G1 gaming.
I plan on overclocking whichever one I get, so I'd also like to know which one would overclock the highest in core speed and memory speed.
I plan on doing only 1080p gaming.
Any other GPU suggestion within this price range from nvidia would also be helpful
Have you considered a r9 280x? They are the same price and the 280x performs quite a bit better. However, if you are set on a gtx 960, I think the gigabyte will do better for overclocking and cooling.
I have but, I want to go with nvidia on this on, do you know any other nvidia cards with the same price to performance ratio?
I cannot possibly recommend the GTX960. It's been a tremendous disappointment, and it's a flat out terrible value.
The R9 280 performs just as well for $40 cheaper. The R9 280x is faster for the same price.
