Need help Choosing a GTX 960 card
Zahid Merchant
9
I'm stuck between the EVGA GTX 960 SSC and GIGABYTE GTX 960 G1 gaming.
I plan on overclocking whichever one I get, so I'd also like to know which one would overclock the highest in core speed and memory speed.
I plan on doing only 1080p gaming.
Any other GPU suggestion within this price range from nvidia would also be helpful
I like the EVGA in that list. They have some nice overclocking software. Have you considered MSI as another manufacture?
Another thing is I don't think either of those cards are using reference PCB. This could be a problem if you are planning on water cooling because you will need to buy specialized water blocks. Just something to think about. Although I am not sure what SCC is. Did you mean SC? If so then I would go with the reference card version.
I chose these 2 b/c they're the same price and i plan on making a dual boot windows/hackintosh pc and these 2 are compatible. I don't plan on water cooling the card. The SSC means it the super super clocked model from the manufacturer
