so im building a cheap gaming computer for a friend who cant afford to buy let alone build one, im using mostly used parts i had lying around my apartment. i.e. my 1050ti that was collecting dust a used atx case from 2002 ddr3 leftover from an old am3 build that i parted out etc.
anyhow i have settled on socket 1150 the only issue i have is the motherboard i wanna use has no vrm cooling and i wanna put an i7 4790 non k cpu in it but im worried that with no vrm heatsink the cpu will be to much for the vrm's thought should i be worried or no? below is a picture of the motherboard i wanna use the only orher issue i have is the atx case only has room for one rear 60mm case fan and one 60mm front case fan so not a lot of airflow should i be worried or will the 4790 be ok even with the lack of vrm heatsinks?
this is the mobo i wanna use. i got the mobo used for 40$ a few months ago if it matters
