Need help choosing a monitor.
Malefic Grindylow
75
I've sort of narrowed it down to 2 monitors, I'm looking for IPS I think the colours will be more important to me. I don't play a lot of FPS' so I decided IPS would be better.
Here are the two I've been looking at:
http://www.amazon.co.uk/Asus-MX239H-LED-backlit-Monitor-80000000/dp/B00A4K9KVG/ref=cm_cr_pr_pb_t
http://www.amazon.co.uk/LG-24EA53VQ-24-inch-Widescreen-Monitor/dp/B00BSOT2LA#productDetails
The Asus is my current choice, but I wanted confirmation/advice on which monitor would be better - or if that one is a solid choice.
Thanks.
Thank you for the reply, that's what I thought too
Have you experience with the monitor? Will the 5ms be noticeably worse than a lower response time?
