Need help choosing a monitor
mcschwalbe
Commendable
Nov 25, 2017
8
Currently I am looking for a new 144hz monitor. My GPU is a 1080 and I play a variety of games but mainly fps and other online competitve shooters. But at the same time I also play a lot on console, meaning, I would like a monitor suitable for both, PC and PS4.
I heard it would be better to play on the native resolution of the screen. Which means I would have to go for 1080p because of the ps4 ( correct me if I am wrong ).
I already saw a lot of monitors like the Benq xl2411P and the viewsonic xg2402 which are all meant to have low input lag which is important for me because I am really comoetitive. But I also like to have decent colours like the samsung c24fg73 seems to have. But with this one input lag is higher and I do not know to what extent the difference is noticeable for an competitve advantage.
I hope someone can help me out with this and share some experiences. Maybe give some other recommendations. Or some tips for a setup combining pc and console.
The Acer Predator XB241H is a great monitor for both PC and PS4 you can use the display port for the PC and an HDMI cable for the PS4, you can't really get an ips panel if you want low input lag.
