Need help choosing a mouse!!
hcstnfrd
132
Okay guys, so I've got a few options, buying in the 30-60 dollar range. Getting it slightly used from a reputable site.
So here are the mice, which should I get?
Razer Lachesis 5600dpi
Razer Imperator 5600dpi
Deathadder 3500 Infrared
R.A.T. 5 4000 dpi
R.A.T. 7 5600 dpi
Mionix Naos 3200
Logitech MX 518
Logitech G9x
Or if you can suggest anything better please do!
Really liking the Lachesis and R.A.T. series but need some opinions!
Thank you very much!!!
you may laugh but some people are quite good with a trackball. if you have bad hands its one of the few choices you have.
that said, i've felt the rat7 and it feels like its about to fall apart at any moment to me. i have a razer deathadder and can vouche for it being a decent mouse, but my past logitech mice have worked great as well.
i wouldnt' worry about features as much as fit. you dont need 5600+ dpi to play games (mine is set below 1200) so just get what mouse actually fits your hand and is comfortable to use.
