need help choosing a new case
Kaitlin Kaschak459
485
7
ok so im doing a pc gaming build using some spare parts my uncle gave me when he upgraded. i have everything but the case.
so what i need to know is will the case in the link below support my mobo GPU and CPU AIO cooler, below are links to each part that needs to be able to fit in the case
link to pc case: http://www.phanteks.com/Enthoo-Pro.html
link to motherboard: https://www.gigabyte.com/Motherboard/GA-X58A-UD3R-rev-20#ov
link to AIO http://us.coolermaster.com/product/Detail/cooling/masterliquid-pro-series/masterliquid-pro-280.html
for those who ask im upgrading from a socket 775 so doing my first major upgrade since 2007
so let me know if this case will fit the parts i listed thanks
I have the Enthoo pro and can guarantee you it will fit everything fine. It has a spacious interior, a pleasure to work with and you get a beautiful result since good cable management is very easy to attain due to the routing points, rubber grommets and cable tie mounting points.
