Hi,
I'm looking into upgrading my current monitor (It's a old LG Flatron 22", don't have the exact model on hand, but it must be around 4 years old)
Basically looking to upgrade the overall quality, energy usage, and size, for a low price mark (below 250CAN$)
I use it for minor gaming (mostly Diablo3), work, browsing, and watch tv series. I won't really watch movies on that screen.
Right now I've pretty much narrowed it down to those too monitors, but I can't decide which one would better fit my needs:
Samsung S24B350H, 24 inch, 2ms, TN, 219,99$
http://www.bestbuy.ca/en-CA/product/samsung-samsung-24-led-monitor-with-2ms-response-time-s24b350h-s24b350h/10193753.aspx?path=95b172b361164a5dbdd2447728fe44b7en02
LG IPS235V, 23 inch, 5ms, IPS, 209.99$ (sale ending today, will go back to 249.99$)
http://www.futureshop.ca/en-CA/product/lg-electronics-lg-23-widescreen-ips-led-monitor-with-5ms-response-time-ips235v-black-ips235v/10195817.aspx?path=0e30ac8f99e85c7c5b98e451f73aa110en02
Both have 1080 resolution. I'd rather have a 1200...but I don't think I can find one at such a low price tag.
So I guess basically the question I can't find answer to is: Am I better off with the extra inch and response time, or with an IPS pannel?
Also, are 24 inches too big for 1080 resolution?
Thanks for the help. I'm also open to suggestions!
