J Jaeger898 Reputable May 5, 2014 20 0 4,510 May 5, 2014 #1 Needing help deciding if I should make the jump to 1440p from 1080p
Solution Invictus321 May 5, 2014 What is your rig? You will take a big FPS hit moving up to 1440p. If you have the grunt for it, then yes yes yes, make the jump! You will not regret it
Invictus321 Reputable Apr 30, 2014 95 0 4,660 May 5, 2014 Solution #2 What is your rig? You will take a big FPS hit moving up to 1440p. If you have the grunt for it, then yes yes yes, make the jump! You will not regret it Upvote 0 Downvote Solution
