Need help choosing a PSU and Case
Is it for gaming, htpc, general office, editing, watching movies. Do you want something you can put on the floor? Do you want something you can take to a lan party? Do you want to upgrade in the future?
The build will be for general computing such as internet bowsing, maybe some htpc or streaming server. I will be using it to play small games like minecraft and I might be using it for programming in the future.
Yes I would like to upgrade in the future.
Does that PSU not seem a little overkill for such a computer. Do you know of any 500-600W PSU's that are really good.
Also do you recommend a good atx case for around 40-50 pounds?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor (£43.14 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£22.49 @ Ebuyer)
Motherboard: Asus H81M-PLUS Micro ATX LGA1150 Motherboard (£39.37 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1866 Memory (£67.11 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£36.50 @ Aria PC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card (£109.98 @ Amazon UK)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case (£37.99 @ Aria PC)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply (£35.09 @ Aria PC)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£11.74 @ CCL Computers)
Total: £403.41
Generated by PCPartPicker 2014-08-15 23:41 BST+0100
A few minor changes, for the better.
That GPU calls for at least a 300w psu by itself, minimum, not counting the processor, board, fans, USB devices and any CPU cooler you may run. PCPartpicker calls for 152w, plus a 300w card, additional wattage for overclocking which could be as much as 30 more watts depending on how much you overclock and how. Consider you wanted some headroom for upgrading in the future, and if you do upgrade pretty much any cpu you buy will use WAY more watts than that G3258 does, and a bit extra for peaks it's a more than you need, but not that much more.
And if you ever do an SLI or Crossfire setup, it might not even be enough depending on the card. You could probably get by with one like this if you don't plan to upgrade later, or maybe even a small upgrade.
http://uk.pcpartpicker.com/part/seasonic-power-supply-ss620gm2
A 750ti with no additional power connector uses the PCIe slot which has a maximum of 75w available. The cards themselves only pull 63-65w. PCIe is 75w, 6-pin is 75w, 6+2(8)-pin is 150w. The cpu is 53w, +@100w oc, +@50w for drives/fans. Total is @263w. The varience comed in with differing amounts of fans at different draws, but basically you are looking at @ a 300w maxed out system.
Unless you know exactly what a card will pull, my best answer is the power connectors will give a safe close bet. Take my 660ti for instance. It has 2x 6-pin so thats 75x2 + 75pcie. So 1 card can theoretically pull 225w. So 2 cards is 450w + 50 for drives/fans + 84cpu + 150 for OC. So I'd be looking for a psu in the 700-750 range for sli. As it is i have just the 1 card so thats @500w. I'm running a Seasonic 520mII, so I'm more than good. Those are maximum numbers though, my 660ti wont ever pull the full 225 unless i OC the hell out of it, and probably not even then, nor will i use 150w on OC, so i have plenty of headroom when it comes to adding stuff like extra case fans, liquid cooling, leds etc. It also means my psu will never reach 100% load output, realistically thats a good thing, it is more efficient, runs cooler and much quieter at 70%-80%.
So, in answer, if you take the original build @300w, you'd just add 75w more for a pcie powered card, total being 375w, so even a builder special cx430 would be enough, for this particular build. Most builds dont have a power draw as low as this as their cpus are 80+ to 125w, and have corresponding OC's of upto 200w+, although average is closer to 60-100w
Gotcha, I might've just added something wrong in the calculator, which I know I shouldn't have been using anyhow as they're not accurate, but I was hurrying as usual with three things at once. I knew it seemed awfully high for that 50w processor and , anyhow, right on.
