Hi, really don't know getting 2 different opinions and not sure what to choose.
so here is my build:
case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811156223
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103996
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125353
HDD: http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148681
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233198
I'm not trying to spend much , like not over $70, someone says, 550W is plenty , and another says , it's just enough so i should get 620W's , but it'll cost more... So i dont know, if i were to get the 620W i would get this : http://www.newegg.ca/Product/Product.aspx?Item=N82E16817207014 ( but it's over 100 so i dont want to get it 🙁.. )
Help is really appreciated! Thanks in advance!
